# Google Assistant Action
Please be aware that the graphical user interface in the Google Home app or on Google Nest devices may not fully support interaction with some of the supported device types. We cannot influence this and rely on Google to implement user interfaces for more devices. Nevertheless, interaction via voice or in writing with Google Assistant should always work.
- Latest Changes
- General Configuration
- Item Configuration
- Switch
- Light
- Light as Group with separate controls
- Scene
- Outlet, Coffee_Maker, WaterHeater, Fireplace
- Valve
- Sprinkler, Vacuum
- Lock
- SecuritySystem as Switch
- SecuritySystem as Group with advanced functionality
- Camera
- Speaker (volume control only)
- TV
- Fan, Hood, AirPurifier
- Awning, Blinds, Curtain, Door, Garage, Gate, Pergola, Shutter, Window
- Charger
- TemperatureSensor
- HumiditySensor
- ClimateSensor
- Thermostat
- Sensor
- Additional Configuration
- Setup & Usage of the Google Home App
- Example Voice Commands
- Frequently Asked Question
# Latest Changes
State of this document
This documentation refers to release v3.9.0 (opens new window) of openHAB Google Assistant (opens new window) published on 2024-01-29
# v3.9.0
- Prepared available configuration options for the upcoming rollout of v4
- Users can start adjusting their setup to use the new configuration options:
Thermostat
:modes
has been renamed tothermostatModes
Fan
:speeds
has been renamed tofanSpeeds
# v3.8.0
- Added
colorTemperatureInverted=true
option toSpecialColorLight
allowing users to invert the percentage to Kelvin conversion for thelightColorTemperature
item
# v3.7.0
- Adjusted
Fan
to usesupportsFanSpeedPercent
option - Inverted
percentage range when usingcolorUnit="percent"
withSpecialColorLight
# v3.6.0
- Added new device types
HumiditySensor
&ClimateSensor
- Changed trait of
TemperatureSensor
to actually show a UI
# v3.5.0
ga="light"
forSpecialColorLight
is replaced byga="specialcolorlight"
useKelvin=true
is replaced bycolorUnit="kelvin"
- Support for color temperature in Mired added
# General Configuration
- The openHAB Cloud Connector configured using myopenHAB.org (opens new window) (Items do NOT need to be exposed to and will not show up on myopenHAB.org (opens new window), this is only required for the IFTTT service!)
- A Google account
- A Google Home / Nest Voice Assistant Device or the Google Assistant on your phone
To expose items (opens new window) to Google Assistent you will need to add metadata (opens new window) in the ga
namespace.
Hint: The value of ga
is not case-sensitive.
# Switch
Device Type | Switch (opens new window) |
Supported Traits | OnOff (opens new window) |
Supported Items | Switch |
Configuration | (optional) inverted=true/false (optional) checkState=true/false |
# Light
Device Type | Light (opens new window) |
Supported Traits | OnOff (opens new window), ColorSetting (opens new window), Brightness (opens new window) (depending on used item type) |
Supported Items | Switch, Dimmer, Color |
Configuration | (optional) inverted=true/false (optional) checkState=true/false (optional) colorTemperatureRange="minK,maxK" |
Dimmer { ga="Light" }
# Light as Group with separate controls
Supported Traits | OnOff (opens new window), ColorSetting (opens new window), Brightness (opens new window) |
Supported Items | Group as SpecialColorLight with the following members:(optional) Number or Dimmer as lightBrightness (optional) Number or Dimmer as lightColorTemperature (optional) Color as lightColor (optional) Switch as lightPower |
Configuration | (optional) colorUnit="percent/kelvin/mired" (optional) checkState=true/false (optional) colorTemperatureRange="minK,maxK" (optional) colorTemperatureInverted=true/false |
Important Hint: If you want to use lightColorTemperature
, you must either set colorUnit
to kelvin
or mired
or define a colorTemperatureRange
, because colorUnit
defaults to percent
If you use colorUnit
as percentage values, the lowest color temperature (warm light) will be converted to 0%, and correspondingly the highest color temperature (cold light) will be converted to 100%.
If you need the inverted values for your device, you can set colorTemperatureInverted=true
. This will convert low Kelvin values to high percentage values and vice versa.
Group lightGroup { ga="SpecialColorLight" [ colorUnit="kelvin", colorTemperatureRange="2000,9000" ] }
Color colorItem (lightGroup) { ga="lightColor" }
Example of a light device where low Kelvin values (warm light) are represented by high percentage values in the color temperature item:
Group lightGroup { ga="SpecialColorLight" [ colorUnit="percent", colorTemperatureRange="2000,6500", colorTemperatureInverted=true ] }
Dimmer colorTemperatureItem (lightGroup) { ga="lightColorTemperature" }
In case you want to control multiple lights using one device with Google Assistant, you can apply the following pattern:
Group:Switch powerItems (lightGroup) { ga="lightPower" }
Group:Dimmer brightnessItems (lightGroup) { ga="lightBrightness" }
Group:Color colorItems (lightGroup) { ga="lightColor" }
Switch powerItem1 (powerItems)
Switch powerItem2 (powerItems)
Dimmer brightnessItem1 (brightnessItems)
Dimmer brightnessItem2 (brightnessItems)
Color colorItem1 (colorItems)
Color colorItem2 (colorItems)
# Scene
Device Type | Scene (opens new window) |
Supported Traits | Scene (opens new window) |
Configuration | (optional) sceneReversible=true/false (optional) checkState=true/false |
Device Type | Outlet (opens new window), Coffee_Maker (opens new window), WaterHeater (opens new window), Fireplace (opens new window) |
Switch { ga="Fireplace" }
# Valve
Device Type | Valve (opens new window) |
Supported Traits | OpenClose (opens new window) |
# Sprinkler, Vacuum
Device Type | Sprinkler (opens new window), Vacuum (opens new window) |
Supported Traits | StartStop (opens new window) |
# Lock
Device Type | Lock (opens new window) |
Supported Traits | LockUnlock (opens new window) |
Supported Items | Contact (no device control), Switch |
Configuration | (optional) inverted=true/false (optional) checkState=true/false (optional) ackNeeded=true/false (optional) pinNeeded="1234" |
# SecuritySystem as Switch
Device Type | SecuritySystem (opens new window) |
Supported Traits | ArmDisarm (opens new window) |
Configuration | (optional) inverted=true/false (optional) checkState=true/false (optional) ackNeeded=true/false (optional) pinNeeded="1234" (optional) pinOnDisarmOnly=true/false (optional) waitForStateChange="2" |
See SecuritySystem as Group
for explanation on the configuration options.
Supported Traits | ArmDisarm (opens new window) StatusReport (opens new window) |
Supported Items | Group as SecuritySystem with the following members: Switch as securitySystemArmed (optional) String as securitySystemArmLevel (optional) Switch as securitySystemTrouble (optional) String as securitySystemTroubleCode (optional) Contact as securitySystemZone |
Configuration | (optional) inverted=true/false (optional) checkState=true/false (optional) ackNeeded=true/false (optional) pinNeeded="1234" (optional) pinOnDisarmOnly=true/false (optional) waitForStateChange="2" (optional) armLevels="L1=Level 1,L2=Level 2" Specifically on Zone Contacts: (required) zoneType="OpenClose/Motion" (optional) blocking=true/false |
Configuring the SecuritySystem
as a Group will enable a lot of advanced functionality.
The Switch
and the Group
configuration support the following configuration parameters:
checkState=true
will compare the current state with the requested one and responds accordingly.ackNeeded=true
will request an acknowledgement before performing an action.pinNeeded="1234"
will request and check the configured PIN before performing an action.pinOnDisarmOnly=true
will enforce the PIN on disarming only. Arming will be done without the PIN.waitForStateChange=0
defines the number of seconds to wait for the security system state to update before checking that the arm/disarm was successful. Defaults to 0 if not specified.
armLevels="Key=Label"
- The label is used for commanding Google Assistant, the key is the matching value sent to openHAB.
When using arm levels, Google will send the mapped level ID (L1,L2 in below example) to the item tagged with securitySystemArmLevel
when you use the arm command. It will then use the status of the item securitySystemArmed
to confirm that arming was successful.
When arming and not using arm levels or disarming, Google will send ON/OFF to the item tagged securitySystemArmed
If arming fails and blocking zones have been configured with securitySystemZone
and blocking=true
, Google will attempt to check for zones that are causing the arming to fail.
ga="securitySystemTrouble"
and ga="securitySystemTroubleCode"
are used in a StatusReport
to report any errors on the alarm, e.g. a flat battery.
Group gHouseAlarm "House Alarm" { ga="SecuritySystem" [ pinNeeded="1234", armLevels="L1=Level 1,L2=Level 2" ] }
Switch alarmArmed (gHouseAlarm) { ga="securitySystemArmed" }
String alarmArmLevel (gHouseAlarm) { ga="securitySystemArmLevel" }
Switch alarmTrouble (gHouseAlarm) { ga="securitySystemTrouble" }
String alarmTroubleErrorCode (gHouseAlarm) { ga="securitySystemTroubleCode" }
Contact frontDoorSensor (gHouseAlarm) { ga="securitySystemZone" [ zoneType="OpenClose", blocking="true" ] }
# Camera
Device Type | Camera (opens new window) |
Supported Traits | CameraStream (opens new window) |
Supported Items | String |
Configuration | (optional) protocols="hls,dash,smooth_stream,progressive_mp4" (choose suitable) |
Device Type | Speaker (opens new window) |
Supported Traits | Volume (opens new window) |
Supported Items | Dimmer |
Configuration | (optional) checkState=true/false (optional) volumeDefaultPercentage="20" (optional) levelStepSize="5" (optional) volumeMaxLevel="100" |
# TV
Device Type | TV (opens new window) |
Supported Traits | OnOff (opens new window), Volume (opens new window), TransportControl (opens new window), InputSelector (opens new window), AppSelector (opens new window), Channel (opens new window) (depending on used members) |
Supported Items | Group as TV with the following members:(optional) Switch as tvPower (optional) Switch as tvMute (optional) Dimmer as tvVolume (optional) String as tvChannel (optional) String as tvInput (optional) String as tvApplication (optional) Player as tvTransport |
Configuration | (optional) checkState=true/false (optional) volumeDefaultPercentage="20" (optional) levelStepSize="5" (optional) volumeMaxLevel="100" (optional) transportControlSupportedCommands="NEXT,PREVIOUS,PAUSE,RESUME" (optional) availableChannels="channelNumber=channelId=channelName:channelSynonym:...,..." (optional) availableInputs="inputKey=inputName:inputSynonym:...,..." (optional) availableApplications="applicationKey=applicationName:applicationSynonym:...,..." (optional) lang="en" |
Group tvGroup { ga="TV" [ volumeDefaultPercentage="20", levelStepSize="10", volumeMaxLevel="100", transportControlSupportedCommands="NEXT,PREVIOUS,PAUSE,RESUME", availableChannels="1=Channel1=NBC,2=Channel2=CBS", availableInputs="hdmi1=xbox:gaming,hdmi2=settopbox", availableApplications="spotify=Spotify:Music,netflix=Netflix:Chill" ] }
# Fan, Hood, AirPurifier
Device Type | Fan (opens new window), Hood (opens new window), AirPurifier (opens new window) |
Supported Traits | OnOff (opens new window), FanSpeed (opens new window) (depending on used item type) |
Supported Items | Switch (no speed control), Dimmer |
Configuration | (optional) checkState=true/false (optional) fanSpeeds="0=away:zero,50=default:standard:one,100=high:two" (optional) lang="en" (optional) ordered=true/false |
Fans (and similar device types, like AirPurifier or Hood) support the FanSpeed
trait.
If you do not specify the fanSpeeds
option, Google will use and expect percentage values for the fan speed.
Otherwise, you will be able to set up and use human speakable modes, e.g. "fast" for 100% or "slow" for 25%.
fanSpeeds
will be a comma-separated list of modes, where the mode value corresponds to the speed value to be passed to the device. The mode or value is followed by an equal sign to list different aliases separated by a colon sign.
So in the example stated below both "high" and "two" would set the speed to 100%.
Some devices may expect a specific value instead of a percentage, like "1" or "2" as speed values. In this case, you can adjust the configuration and replace the percentage values with the values that the device expects. (e.g.: fanSpeeds="0=away:zero,1=default:standard:one,2=high:two"
The option ordered
will tell the system that your list is ordered and you will then be able to also say "faster" or "slower" and Google will use the next or previous speed.
Dimmer { ga="Fan" [ fanSpeeds="0=away:zero,50=default:standard:one,100=high:two", lang="en", ordered=true ] } # Using specific percentage values for the speed
Switch { ga="Hood" } # No speed control - only on/off
Dimmer { ga="AirPurifier" } # Using percentage values for the speed
Dimmer { ga="AirPurifier" [ fanSpeeds="0=away:zero,1=low:one,2=medium:two,3=high:three,4=turbo:four", lang="en", ordered=true ] } # Using specific speed modes/values, which differ from percentage
Switch { ga="AirPurifier" } # No speed control - only on/off
Device Type | Awning (opens new window), Blinds (opens new window), Curtain (opens new window), Door (opens new window), Garage (opens new window), Gate (opens new window), Pergola (opens new window), Shutter (opens new window), Window (opens new window) |
Supported Traits | OpenClose (opens new window), StartStop (opens new window) |
Supported Items | Contact (no device control), Switch (no open percentage), Rollershutter |
Configuration | (optional) discreteOnly=true/false (optional) queryOnly=true/false (optional) inverted=true/false (optional) checkState=true/false |
Blinds and similar devices should always use the Rollershutter
item type for proper functionality.
Since Google and openHAB use the opposite percentage value for "opened" and "closed", the action will translate this automatically.
If the values are still inverted in your case, you can state the inverted=true
option for all Rollershutter
items.
Rollershutter { ga="Awning" }
Switch { ga="Door" }
Rollershutter { ga="Garage" }
Contact { ga="Gate" }
Rollershutter { ga="Window" }
# Charger
Device Type | Charger (opens new window) |
Supported Traits | EnergyStorage (opens new window) |
Supported Items | Group as Charger with the following members:(optional) Switch as chargerCharging (optional) Switch as chargerPluggedIn (optional) Number or Dimmer as chargerCapacityRemaining (optional) Number or Dimmer as chargerCapacityUntilFull |
Configuration | (optional) checkState=true/false (optional) isRechargeable=true/false (optional) unit="PERCENTAGE" |
The configuration option unit
supports the following values: PERCENTAGE
(default), SECONDS
, MILES
, KILOMETERS
, KILOWATT_HOURS
The setting isRechargeable
defaults to false
if not explicitly set to true
If no chargerCharging
item is specified, the device will only support queries.
Group chargerGroup { ga="Charger" [ isRechargeable=true, unit="KILOWATT_HOURS" ] }
Switch chargingItem (chargerGroup) { ga="chargerCharging" }
Switch pluggedInItem (chargerGroup) { ga="chargerPluggedIn" }
Number capacityRemainItem (chargerGroup) { ga="chargerCapacityRemaining" }
Number capacityFullItem (chargerGroup) { ga="chargerCapacityUntilFull" }
# TemperatureSensor
Device Type | Sensor (opens new window) |
Supported Traits | TemperatureControl (opens new window), TemperatureSetting (opens new window) |
Supported Items | Number |
Configuration | (optional) useFahrenheit=true/false |
Number { ga="TemperatureSensor" [ useFahrenheit=true ] }
# HumiditySensor
Supported Traits | HumiditySetting (opens new window) |
Number { ga="HumiditySensor" }
# ClimateSensor
Supported Traits | HumiditySetting (opens new window), TemperatureControl (opens new window), TemperatureSetting (opens new window) |
Supported Items | Group as ClimateSensor with the following members:(optional) Number as humidityAmbient (optional) Number as temperatureAmbient |
Group sensorGroup { ga="ClimateSensor" [ useFahrenheit=true ] }
Number temperatureItem (sensorGroup) { ga="temperatureAmbient" }
Number humidityItem (sensorGroup) { ga="humidityAmbient" }
# Thermostat
Device Type | Thermostat (opens new window) |
Supported Traits | TemperatureSetting (opens new window) |
Supported Items | Group as Thermostat with the following members:String or Number as thermostatMode (optional) Number as thermostatHumidityAmbient (optional) Number as thermostatTemperatureAmbient (optional) Number as thermostatTemperatureSetpoint (optional) Number as thermostatTemperatureSetpointLow (optional) Number as thermostatTemperatureSetpointHigh |
Configuration | (optional) checkState=true/false (optional) useFahrenheit=true/false (optional) thermostatTemperatureRange="10,30" (optional) thermostatModes="off=OFF:WINDOW_OPEN,heat=COMFORT:BOOST,eco=ECO,on=ON,auto" |
To change the temperature unit to Fahrenheit, add the config option useFahrenheit=true
to the thermostat group.
To set the temperature range your thermostat supports, add the config option thermostatTemperatureRange="10,30"
to the thermostat group. Those values always have to be provided in Celsius!
If your thermostat supports a range for the setpoint you can use both thermostatTemperatureSetpointLow
and thermostatTemperatureSetpointHigh
instead of the single thermostatTemperatureSetpoint
item.
To map the default thermostat modes of Google (opens new window) (on, off, heat, cool, etc.) to custom ones for your specific setup, you can use the thermostatModes
config option on the thermostat group.
E.g. [ thermostatModes="off=OFF:WINDOW_OPEN,heat=COMFORT:BOOST,eco=ECO,on=ON,auto" ]
will enable the following five modes in Google Home "off, heat, eco, on, auto"
that will be translated to "OFF, COMFORT, ECO, ON, auto"
. You can specify alternative conversions using the colon sign, so that in the former example "BOOST" in openHAB would also be translated to "heat" in Google. For the translation of Google modes to openHAB always the first option after the equal sign is used.
By default, the integration will provide "off,heat,cool,on,heatcool,auto,eco"
However, it is recommended to prefer the TemperatureSensor
type for simple temperature reports (but currently there is no UI support in Google Home).
Group thermostatGroup { ga="Thermostat" [ thermostatModes="off=OFF:WINDOW_OPEN,heat=COMFORT:BOOST,eco=ECO,on=ON,auto", thermostatTemperatureRange="10,30", useFahrenheit=false ] }
Number temperatureItem (thermostatGroup) { ga="thermostatTemperatureAmbient" }
# Sensor
Supported Traits | SensorState (opens new window) |
Supported Items | Number, Dimmer |
Configuration | sensorName="SmokeLevel" valueUnit="PARTS_PER_MILLION" states="no smoke=10,smoke detected=50,high=90" |
# Additional Configuration
If you do not want to adjust your labels to be human spellable, you can use the "name" config option in the metadata: [ name="Kitchen Lights" ]
. This will overwrite the label as the device's name.
Furthermore, you can state synonyms for the device name: Switch KitchenLight "Kitchen Lights" { synonyms="Top Light", ga="Light" }
To ease setting up new devices you can add a room hint: [ roomHint="Living Room" ]
For devices supporting the OpenClose trait, the attributes [ discreteOnly=false, queryOnly=false ]
can be configured.
discreteOnly
defaults to false. When set to true, this indicates that the device must either be fully open or fully closed (that is, it does not support values between 0% and 100%). An example of such a device may be a valve.queryOnly
defaults to false. Is set to true forContact
items. Indicates if the device can only be queried for state information and cannot be controlled. Sensors that can only report open state should set this field to true.
All device types support checking the current state before sending an updated state by a command. This can be enabled by setting [ checkState=true ]
in the metadata. When this is enabled, the current state of the target item is queried and compared to the potential new state triggered by the command. If it is identical, a special error message is triggered and communicated to the user.
add metadata via console:
smarthome:metadata add BedroomLights ga Light
add metadata using the REST API:
# Two-Factor-Authentication
For some actions, Google recommends to use TFA (Two-Factor-Authentication) to prevent accidental or unauthorized triggers of sensitive actions. See Two-factor authentication | Actions on Google Smart Home (opens new window).
# Setup & Usage of the Google Home App
- Set up the voice-activated speaker or Android phone (version 6+) with your Google account.
- Start the Google Home app on your phone.
- Go to the settings part:
Home > Settings
- Press the
+ Add device
button in the Settings screen.
- Choose
Works with Google
- Search and select
openHAB
- Continue with linking your account.
- Login at
myopenhab.org
with your username and password.
- Make sure to assign your devices to rooms to properly use voice commands.
- You can now control your devices from the Google Assistant and Google Home.
# Example Voice Commands
- Turn on Office Lights.
- Set Office Lights to 35%.
- Open/Close the blinds
- Turn off Pool Waterfall.
- Turn on House Fan.
- Turn on Home Theater Scene.
# Frequently Asked Question
- Say:
Hey Google, sync my devices
- Remove all the metadata.
Switch TestSwitch "Test Switch" { ga="Switch" }
- Relink your account.
