# Home Connect Binding
# Bridge
# Devices
# experimental support
Home appliance | Thing Type ID |
Dishwasher | dishwasher |
Washer | washer |
Washer / Dryer combination | washerdryer |
Dryer | dryer |
Oven | oven |
Hood | hood |
Cooktop | hob |
Refrigerator Freezer | fridgefreezer |
Coffee Machine | coffeemaker |
Channel Type ID | Item Type | Read only | Description | Available on thing |
power_state | Switch | false | This setting describes the current power state of the home appliance. | dishwasher, oven, coffeemaker, hood, hob |
door_state | Contact | true | This status describes the door state of a home appliance. A status change is either triggered by the user operating the home appliance locally (i.e. opening/closing door) or automatically by the home appliance (i.e. locking the door). | dishwasher, washer, washerdryer, dryer, oven, fridgefreezer |
operation_state | String | true | This status describes the operation state of the home appliance. | dishwasher, washer, washerdryer, dryer, oven, hood, hob, coffeemaker |
remote_start_allowance_state | Switch | true | This status indicates whether the remote program start is enabled. This can happen due to a programmatic change (only disabling), or manually by the user changing the flag locally on the home appliance, or automatically after a certain duration - usually in 24 hours. | dishwasher, washer, washerdryer, dryer, oven, hood, coffeemaker |
remote_control_active_state | Switch | true | This status indicates whether the allowance for remote controlling is enabled. | dishwasher, washer, washerdryer, dryer, oven, hood, hob |
active_program_state | String | true | This status describes the active program of the home appliance. | dishwasher, washer, washerdryer, dryer, oven, hood, hob, coffeemaker |
selected_program_state | String | false | This state describes the selected program of the home appliance. | dishwasher, washer, washerdryer, dryer, oven, hob, coffeemaker |
remaining_program_time_state | Number:Time | true | This status indicates the remaining program time of the home appliance. | dishwasher, washer, washerdryer, dryer, oven |
elapsed_program_time | Number:Time | true | This status indicates the elapsed program time of the home appliance. | oven |
program_progress_state | Number:Dimensionless | true | This status describes the program progress of the home appliance in percent. | dishwasher, washer, washerdryer, dryer, oven, coffeemaker |
duration | Number:Time | true | This status describes the duration of the program of the home appliance. | oven |
oven_current_cavity_temperature | Number:Temperature | true | This status describes the current cavity temperature of the home appliance. | oven |
setpoint_temperature | Number:Temperature | false | This status describes the setpoint/target temperature of the home appliance. | oven |
laundry_care_washer_temperature | String | false | This status describes the temperature of the washing program of the home appliance. | washer, washerdryer |
laundry_care_washer_spin_speed | String | false | This status defines the spin speed of a washer program of the home appliance. | washer, washerdryer |
laundry_care_washer_idos1_level | String | false | This status defines the i-Dos 1 dosing level of a washer program of the home appliance (if appliance supports i-Dos). | washer |
laundry_care_washer_idos2_level | String | false | This status defines the i-Dos 2 dosing level of a washer program of the home appliance (if appliance supports i-Dos). | washer |
laundry_care_washer_idos1 | Switch | true | This status indicates whether i-Dos 1 is activated for a washer program of the home appliance. (If appliance supports i-Dos) | washer |
laundry_care_washer_idos2 | Switch | true | This status indicates whether i-Dos 2 is activated for a washer program of the home appliance. (If appliance supports i-Dos) | washer |
laundry_care_washer_vario_perfect | String | true | This status defines the vario perfect mode of a washer program of the home appliance. | washer, washerdryer |
laundry_care_washer_less_ironing | Switch | true | This status indicates whether less ironing is activated for a washer program of the home appliance. | washer, washerdryer |
laundry_care_washer_pre_wash | Switch | true | This status indicates whether the pre-wash is activated for a washer program of the home appliance. | washer, washerdryer |
laundry_care_washer_rinse_plus | String | true | This status defines the number of additional rinses of a washer program of the home appliance. | washer, washerdryer |
laundry_care_washer_rinse_hold | Switch | true | This status indicates whether the spin function is deactivated for a washer program of the home appliance (washing will remain in the water after the last rinse cycle). | washer, washerdryer |
laundry_care_washer_soak | Switch | true | This status indicates whether the soaking is activated for a washer program of the home appliance. | washer, washerdryer |
laundry_care_washer_load_recommendation | Number:Mass | true | This channel indicates the maximum laundry load recommended for a program of the home appliance. | washer, washerdryer |
program_energy | Number:Dimensionless | true | This channel provides the estimated energy required in percentage for a program of the home appliance. | washer, washerdryer |
program_water | Number:Dimensionless | true | This channel provides the estimated water required in percentage for a program of the home appliance. | washer, washerdryer |
dryer_drying_target | String | false | This status defines the desired dryness of a program of the home appliance. | dryer, washerdryer |
setpoint_temperature_refrigerator | Number:Temperature | false | Target temperature of the refrigerator compartment (range depends on appliance - common range 2 to 8°C). | fridgefreezer |
setpoint_temperature_freezer | Number:Temperature | false | Target temperature of the freezer compartment (range depends on appliance - common range -16 to -24°C). | fridgefreezer |
super_mode_refrigerator | Switch | false | The setting has no impact on setpoint temperatures but will make the fridge compartment cool to the lowest possible temperature until it is disabled manually by the customer or by the HA because of a timeout. | fridgefreezer |
super_mode_freezer | Switch | false | This setting has no impact on setpoint temperatures but will make the freezer compartment cool to the lowest possible temperature until it is disabled manually by the customer or by the home appliance because of a timeout. | fridgefreezer |
coffeemaker_drip_tray_full_state | Switch | true | Is coffee maker drip tray full? | coffeemaker |
coffeemaker_water_tank_empty_state | Switch | true | Is coffee maker water tank empty? | coffeemaker |
coffeemaker_bean_container_empty_state | Switch | true | Is coffee maker bean container empty? | coffeemaker |
hood_venting_level | String | true | This option defines the required fan setting of the hood. | hood |
hood_intensive_level | String | true | This option defines the intensive setting of the hood. | hood |
hood_program_state | String | false | Adds hood controller actions to the appliance. The following commands are supported: stop , venting1 , venting2 , venting3 , venting4 , venting5 , ventingIntensive1 , ventingIntensive1 , automatic and delayed . Furthermore it is possible to send raw (Home Connect JSON payload) to the home appliance. | hood |
basic_actions_state | String | false | Adds basic controller actions to the appliance. The following basic commands are supported: start (start current selected program), stop (stop current program) and selected (show current program information). Furthermore it is possible to send raw (Home Connect JSON payload) to the home appliance. | dishwasher, oven, washer, washerdryer, dryer, coffeemaker |
functional_light_state | Switch | false | This setting describes the current functional light state of the home appliance. | hood |
functional_light_brightness_state | Dimmer | false | This setting describes the brightness state of the functional light. | hood |
ambient_light_state | Switch | false | This setting describes the current ambient light state of the home appliance. | dishwasher, hood |
ambient_light_brightness_state | Dimmer | false | This setting describes the brightness state of the ambient light. INFO: Please note that the brightness can't be set if the ambient light color is set to CustomColor . | dishwasher, hood |
ambient_light_color_state | String | false | This setting describes the current ambient light color state of the home appliance. | dishwasher, hood |
ambient_light_custom_color_state | Color | false | This setting describes the custom color state of the ambient light. HSB color commands are supported as well as hex color string e.g. #11ff00 . INFO: Please note that the brightness can't be set. | dishwasher, hood |
# 1. Preconditions
- Please create an account at Home Connect (opens new window) and add your physical appliance to your account.
- Test the connection to your physical appliance via mobile app (Apple App Store (iOS) (opens new window) or Google Play Store (Android) (opens new window)).
Create an account at https://developer.home-connect.com (opens new window) and login.
Please make sure you've added your associated Home Connect account email at https://developer.home-connect.com/user/me/edit (opens new window). You should fill in your email address, which you use for the official Android or iOS app, at
Default Home Connect User Account for Testing
.Register / Create an application at https://developer.home-connect.com/applications (opens new window)
Application ID: e.g.
openhab-binding
OAuth Flow: Authorization Code Grant Flow
Home Connect User Account for Testing: the associated user account email from Home Connect (opens new window)
Redirect URIs: add your openHAB URL followed by
/homeconnect
for example:http://192.168.178.34:8080/homeconnect
orhttps://myhome.domain.com/homeconnect
One Time Token Mode: keep unchecked
Proof Key for Code Exchange: keep unchecked
NOTE: You might get an error (
403 - Forbidden
) in case you entered a bare IP of your local openHAB instance. In that case, use your instance's hostname instead (e.g. for openhabianhttp://openhabian:8080/homeconnect
) and try again.
After your application has been created, you should see the Client ID and Client Secret of the application. Please save these for later.
- Go to the Inbox and press the add button
- Choose
- Select
Home Connect API
- Setup and save thing
- client id: your application client id
- client secret: your application client secret
- simulator: false
- Now navigate to the URL (
Redirct URI
) you've added to your Home Connect application in the previous step (2.3). For examplehttp://192.168.178.80:8080/homeconnect
. - Please follow the steps shown to authenticate your binding. You can redo this step every time. For example if you have authentication problems, just start wizard again.
- That's it! Now you can use autodiscovery to add devices. Your devices should show up if you start a device scan in the openHAB UI.
If you prefer to configure everything via file instead of openHAB UI, here are some examples. In order to get your haId
you might use the discover feature in UI, copy the appliance's ID and paste it into your *.things
# things/homeconnect.things
// Thing configurations
Thing dishwasher dishwasher1 "Dishwasher" [ haId="SIEMENS-HCS02DWH1-6F2FC400C1EA4A" ]
Thing washer washer1 "Washer" [ haId="SIEMENS-HCS03WCH1-1F35EC2BE34A0F" ]
Thing fridgefreezer fridge1 "Fridge Freezer [ haId="SIEMENS-HCS05FRF1-7B3FA5EB3D885B" ]
Thing oven oven1 "Oven" [ haId="BOSCH-HCS01OVN1-2132B6FA25BA21" ]
Thing dryer dryer1 "Dryer" [ haId="BOSCH-HCS04DYR1-3921C766AD5BAF" ]
Thing coffeemaker coffee1 "Coffee machine" [ haId="BOSCH-HCS06COM1-2140A8821AE7AB" ]
Thing washerdryer washerdryer1 "Washerdryer" [ haId="BOSCH-HCS06COM1-2140A8821AE7AB" ]
Thing fridgefreezer fridgefreezer1 "Fridge/Freezer" [ haId="BOSCH-HCS06COM1-2140A8821AE7AB" ]
Thing hood hood1 "Hood" [ haId="BOSCH-HCS06COM1-2140A8821AE7AB" ]
Thing hob hob1 "Hob" [ haId="BOSCH-HCS06COM1-2140A8821AE7AB" ]
# items/homeconnect.items
The channel parameter uses the following syntax: homeconnect:<thing type id>:<bridge id>:<thing id>:<channel type id>
. For example: homeconnect:dishwasher:api_bridge_at_home:dishwasher1:power_state
// dishwasher
Switch Dishwasher_PowerState "Power State" {channel="homeconnect:dishwasher:api_bridge_at_home:dishwasher1:power_state"}
Contact Dishwasher_DoorState "Door State" {channel="homeconnect:dishwasher:api_bridge_at_home:dishwasher1:door_state"}
String Dishwasher_OperationState "Operation State" {channel="homeconnect:dishwasher:api_bridge_at_home:dishwasher1:operation_state"}
Switch Dishwasher_RemoteStartAllowanceState "Remote Start Allowance State" {channel="homeconnect:dishwasher:api_bridge_at_home:dishwasher1:remote_start_allowance_state"}
Switch Dishwasher_RemoteControlActiveState "Remote Control Activation State" {channel="homeconnect:dishwasher:api_bridge_at_home:dishwasher1:remote_control_active_state"}
String Dishwasher_SelectedProgramState "Selected Program" {channel="homeconnect:dishwasher:api_bridge_at_home:dishwasher1:selected_program_state"}
String Dishwasher_ActiveProgramState "Active Program" {channel="homeconnect:dishwasher:api_bridge_at_home:dishwasher1:active_program_state"}
Number:Time Dishwasher_RemainingProgramTimeState "Remaining Program Time" {channel="homeconnect:dishwasher:api_bridge_at_home:dishwasher1:remaining_program_time_state"}
Number:Dimensionless Dishwasher_ProgramProgressState "Progress State" {channel="homeconnect:dishwasher:api_bridge_at_home:dishwasher1:program_progress_state"}
String Dishwasher_BasicActionsState "Basic Control" {channel="homeconnect:dishwasher:api_bridge_at_home:dishwasher1:basic_actions_state"}
// oven
Switch Oven_PowerState "Power State" {channel="homeconnect:oven:api_bridge_at_home:oven1:power_state"}
Contact Oven_DoorState "Door State" {channel="homeconnect:oven:api_bridge_at_home:oven1:door_state"}
String Oven_OperationState "Operation State" {channel="homeconnect:oven:api_bridge_at_home:oven1:operation_state"}
Switch Oven_RemoteStartAllowanceState "Remote Start Allowance State" {channel="homeconnect:oven:api_bridge_at_home:oven1:remote_start_allowance_state"}
Switch Oven_RemoteControlActiveState "Remote Control Activation State" {channel="homeconnect:oven:api_bridge_at_home:oven1:remote_control_active_state"}
String Oven_SelectedProgramState "Selected Program" {channel="homeconnect:oven:api_bridge_at_home:oven1:selected_program_state"}
String Oven_ActiveProgramState "Active Program" {channel="homeconnect:oven:api_bridge_at_home:oven1:active_program_state"}
Number:Time Oven_RemainingProgramTimeState "Remaining Program Time" {channel="homeconnect:oven:api_bridge_at_home:oven1:remaining_program_time_state"}
Number:Dimensionless Oven_ProgramProgressState "Progress State" {channel="homeconnect:oven:api_bridge_at_home:oven1:program_progress_state"}
Number:Time Oven_ElapsedProgramTime "Elapsed Program Time" {channel="homeconnect:oven:api_bridge_at_home:oven1:elapsed_program_time"}
Number:Time Oven_Duration "Program Duration" {channel="homeconnect:oven:api_bridge_at_home:oven1:duration"}
Number:Temperature Oven_CurrentCavityTemperature "Current Temperature" {channel="homeconnect:oven:api_bridge_at_home:oven1:oven_current_cavity_temperature"}
Number:Temperature Oven_SetpointTemperature "Set Temperature" {channel="homeconnect:oven:api_bridge_at_home:oven1:setpoint_temperature"}
String Oven_BasicActionsState "Basic Control" {channel="homeconnect:oven:api_bridge_at_home:oven1:basic_actions_state"}
// washer
Switch Washer_PowerState "Power State" {channel="homeconnect:washer:api_bridge_at_home:washer1:power_state"}
Contact Washer_DoorState "Door State" {channel="homeconnect:washer:api_bridge_at_home:washer1:door_state"}
String Washer_OperationState "Operation State" {channel="homeconnect:washer:api_bridge_at_home:washer1:operation_state"}
Switch Washer_RemoteStartAllowanceState "Remote Start Allowance State" {channel="homeconnect:washer:api_bridge_at_home:washer1:remote_start_allowance_state"}
Switch Washer_RemoteControlActiveState "Remote Control Activation State" {channel="homeconnect:washer:api_bridge_at_home:washer1:remote_control_active_state"}
String Washer_SelectedProgramState "Selected Program" {channel="homeconnect:washer:api_bridge_at_home:washer1:selected_program_state"}
String Washer_ActiveProgramState "Active Program" {channel="homeconnect:washer:api_bridge_at_home:washer1:active_program_state"}
Number:Time Washer_RemainingProgramTimeState "Remaining Program Time" {channel="homeconnect:washer:api_bridge_at_home:washer1:remaining_program_time_state"}
Number:Dimensionless Washer_ProgramProgressState "Progress State" {channel="homeconnect:washer:api_bridge_at_home:washer1:program_progress_state"}
String Washer_LaundryCareWasherTemperature "Temperature" {channel="homeconnect:washer:api_bridge_at_home:washer1:laundry_care_washer_temperature"}
String Washer_LaundryCareWasherSpinSpeed "Spin Speed" {channel="homeconnect:washer:api_bridge_at_home:washer1:laundry_care_washer_spin_speed"}
String Washer_LaundryCareWasherIdos1Level "i-Dos 1 Level" {channel="homeconnect:washer:api_bridge_at_home:washer1:laundry_care_washer_idos1_level"}
String Washer_LaundryCareWasherIdos2Level "i-Dos 2 Level" {channel="homeconnect:washer:api_bridge_at_home:washer1:laundry_care_washer_idos2_level"}
Switch Washer_LaundryCareWasherIdos1 "i-Dos 1 State" {channel="homeconnect:washer:api_bridge_at_home:washer1:laundry_care_washer_idos1"}
Switch Washer_LaundryCareWasherIdos2 "i-Dos 2 State" {channel="homeconnect:washer:api_bridge_at_home:washer1:laundry_care_washer_idos2"}
Switch Washer_LaundryCareWasherVarioPerfect "Vario Perfect State" {channel="homeconnect:washer:api_bridge_at_home:washer1:laundry_care_washer_vario_perfect"}
Switch Washer_LaundryCareWasherLessIroning "Ironing State" {channel="homeconnect:washer:api_bridge_at_home:washer1:laundry_care_washer_less_ironing"}
Switch Washer_LaundryCareWasherPreWash "Prewash State" {channel="homeconnect:washer:api_bridge_at_home:washer1:laundry_care_washer_pre_wash"}
Switch Washer_LaundryCareWasherRinsePlus "Amount Aadditional Rinses" {channel="homeconnect:washer:api_bridge_at_home:washer1:laundry_care_washer_rinse_plus"}
Switch Washer_LaundryCareWasherRinseHold "Spin Hold" {channel="homeconnect:washer:api_bridge_at_home:washer1:laundry_care_washer_rinse_hold"}
Switch Washer_LaundryCareWasherSoak "Soaking State" {channel="homeconnect:washer:api_bridge_at_home:washer1:laundry_care_washer_soak"}
Number:Mass Washer_LaundryCareWasherLoadRecommendation "Load Recommendation" {channel="homeconnect:washer:api_bridge_at_home:washer1:laundry_care_washer_load_recommendation"}
Number:Dimensionless Washer_ProgramEnergy "Estimated Energy Consumption" {channel="homeconnect:washer:api_bridge_at_home:washer1:program_energy"}
Number:Dimensionless Washer_ProgramWater "Estimated Water Consumption" {channel="homeconnect:washer:api_bridge_at_home:washer1:program_water"}
String Washer_BasicActionsState "Basic Control" {channel="homeconnect:washer:api_bridge_at_home:washer1:basic_actions_state"}
# Home Connect Console
The binding comes with a separate user interface, which is reachable through the web browser http(s)😕/[YOUROPENHAB]:[YOURPORT]/homeconnect (e.g. http://192.168.178.100:8080/homeconnect
Features:
- overview of your bridges and appliances
- send commands to your appliances
- see latest API requests
- see received events from the Home Connect backend
- API request counts
INFO: If you have a problems with your installation, please always provide request and event exports.
# How To
This can happen if
- your openHAB instance was offline for a longer period or
- new terms weren't accepted or
- a technical problem occurred.
Thing "<thingUID>" changed
// send push, email, ...
Currently, not all program options of a device are available as items in openHAB. For example, you cannot change the Fill quantity
of a coffee maker program. If you wish to start a program with a custom setting, you can send a special command to the item of type basic_actions_state
INFO: Only for advanced users. You need to know how to use the
curl
command. Alternatively you you can use the binding UI to trigger the commands.
You have a couple options to get the program settings payload.
- On the physical device, select your desired program with the appropriate options.
- Open the appliance section of the binding UI (http(s)😕/[YOUROPENHAB]:[YOURPORT]/appliances) and click the 'Selected Program' button.
Copy the JSON payload. In a further step, this payload will be used to start the program.
# 2. Start program
After you've extracted the desired program command, you can start your program via openHAB rule or through a curl
command.
# in rule
Example rule:
rule "trigger program"
Time cron "0 32 13 ? * * *"
Please replace homeconnect_CoffeeMaker_BOSCH_HCS06COM1_B95E5103934D_basic_actions_state
with your item name (of channel type basic_actions_state
# via curl
Example command:
OAuth is storing data in two files: your access tokens in the file userdata/jsondb/StorageHandler.For.OAuthClientService.json
and the encryption/decryption key in the file userdata/config/SymmetricKeyCipher.config
Consider backing up and restoring these two files when installing a new openHAB server from scratch.
Otherwise, all you need to do is re-authorize your bridge.
# FAQ
The channel of type remote_start_allowance_state
is read only. You can only enable it directly on the physical appliance.
# In case of error...
Please check log UI (http(s)😕/[YOUROPENHAB]:[YOURPORT]/homeconnect) and ask for help in the community forum or on github. Please provide request and event exports.
# Rate limit reached
The Home Connect API enforces rate limits (opens new window). If you have a lot of 429
response codes in your request log section (http(s)😕/[YOUROPENHAB]:[YOURPORT]/homeconnect/log/requests), please check the error response.
# Error message 'Program not supported', 'Unsupported operation' or 'SDK.Error.UnsupportedOption'
Not all appliance programs and program options are supported by the Home Connect API. Unfortunately you can't use them. You will see error messages like the following in the binding UI (request log):
"error": {
"error": {
- You can use the openHAB UI and start a scan.
- You can use Home Connect binding UI. Please have a look at the first API request.
