# Tellstick Binding
dimmer
- Switchable Device - On/Off only could be lamps or other electronic equipment.
switch
- Sensors - Temperature- and humidity-sensors.
sensor
telldus-core
- Telldus Live Bridge - Telldus Cloud service, all devices with online access.
telldus-live
- Telldus Local Bridge - Telldus Local API, Tellstick Net v2/Tellstick ZNet Lite v1/v2.
telldus-local
# Switchbased sensors workaround
switch
Things instead of typecontact
. There is technically no way of distinguish them apart from regulurswitch
Things. For using them as sensors only (not paired to a lamp) please consult the workaround in the channel section.
# Binding Configuration
# Dimmers & switches
Use the option repeat
for that. Default resend count is 2.
# Bridges
Depending on your Tellstick device type there is different ways of using this binding.
The binding implements three different APIs:
3) Telldus Local which is a REST based local service maintained by Telldus.
Model | Telldus Core | Telldus Live | Local REST API | Verified working with openHAB |
Tellstick Basic | X | X | X | |
Tellstick Duo | X | X | X | |
Tellstick Net v.1 | X | X | ||
Tellstick Net v.2 | X | X | ||
Tellstick ZNet Lite v.1 | X | X | X | |
Tellstick ZNet Lite v.2 | X | X |
# Telldus Core Bridge
java -d32 -version
For changing architecture in Linux check out:
dpkg --add-architecture
The telldus-core bridge uses a library on the local computer which is a .dll
file for Windows and a .so
file for Linux. The default one is usually correct.
Optional:
# Telldus Live Bridge
To configure Telldus Live you have request OAuth tokens from Telldus. Goto this page https://pa-api.telldus.com/keys/index (opens new window) and request your keys and update the config.
Required:
- privateKey: Private key
- publicKey: Public key
- token: Token
- tokenSecret: Token secret
Optional:
# Telldus Local Bridge
Required:
- ipAddress: Local IP address of your Tellstick device
- accessToken: Access Token
Optional:
- refreshInterval: How often we should contact Telldus Local to check for updates (in ms)
Channel Type ID | Item Type | Description |
dimmer | Number | This channel indicates the current dim level |
state | Switch | This channel indicates whether a device is turned on or off. |
timestamp | DateTime | This channel reports the last time this device state changed. |
humidity | Number:Dimensionless | This channel reports the current humidity in percentage. |
temperature | Number:Temperature | This channel reports the current temperature. |
timestamp | DateTime | This channel reports the last time this sensor was updates. |
watt | Number:Power | This channel reports the current watt. |
ampere | Number:ElectricCurrent | This channel reports the current ampere. |
windgust | Number:Speed | The current peak wind gust. |
winddirection | Number:Angle | The current wind direction. |
windaverage | Number:Speed | The current wind average. |
rainrate | Number:Length | This current rate of rain. |
raintotal | Number:Length | The total rain. |
All switchbased sensors are binary and the goal is to represent them as a contact
item in openHAB. Eg. a door is open or closed and can't be altered by sending a radio signal.
rule "proxy_front_door_on"
rule "proxy_front_door_off"
# tellstick.things
# tellstick.items
