# Developing a Binding
# Describing Things
Each functionality of the Thing should be modelled as a Channel
# The ThingHandlerFactory
For each Thing the binding must provide a proper ThingHandler
implementation that is able to handle the communication.
is responsible for creating ThingHandler
instances.
Every binding must implement a ThingHandlerFactory
and register it as OSGi service so that the runtime knows which class needs to be called for creating and handling things.
When a new Thing is added, the openHAB runtime queries every ThingHandlerFactory
for support of the ThingType by calling the supportsThingType
method.
When the method returns true
, the runtime calls createHandler
, which should then return a proper ThingHandler
implementation.
A weather bindings WeatherHandlerFactory
for example supports only one ThingType and instantiates a new WeatherHandler
for a given thing:
@NonNullByDefault
@Override
@Override
return null;
Constants like the THING_TYPE_WEATHER
UID and also Channel UIDs are typically defined inside a public BindingConstants
class.
# The ThingHandler
A ThingHandler
handles the communication between openHAB and an entity from the real world, e.g. a physical device, a web service, represented by a Thing
openHAB provides an abstract base class named BaseThingHandler
Most of the explanations are based on the assumption, that the binding inherits from the BaseThingHandler in all concrete ThingHandler
implementations.
Nevertheless if there are reasons why you can not use the base class, the binding can also directly implement the ThingHandler
interface.
If the framework wants the binding to do something or just notify it about changes,
it calls methods like handleCommand
, handleUpdate
or thingUpdated
The BaseThingHandler
provides convenience methods like updateState
, updateStatus
updateThing
or triggerChannel
, that can be used to inform the framework about changes.
TODO
# Lifecycle
The ThingHandler
has two important lifecycle methods: initialize
and dispose
The initialize
method is called when the handler is started and dispose
just before the handler is stopped.
# Startup
Handler is registered:
ThingHandler
instance is created by aThingHandlerFactory
and tracked by the framework. In addition, the handler can be registered as a service if required, e.g. asFirmwareUpdateHandler
orConfigStatusProvider
.Handler is initialized:
ThingHandler.initialize()
is called by the framework in order to initialize the handler. This method is only called if all 'required' configuration parameters of the Thing are present. The handler is ready to work (methods likehandleCommand
,handleUpdate
orthingUpdated
can be called).The diagram below illustrates the startup of a handler in more detail. The life cycle is controlled by the
ThingManager
The ThingManager
mediates the communication between a Thing
and a ThingHandler
from the binding.
The ThingManager
creates for each Thing a ThingHandler
instance using a ThingHandlerFactory
Therefore, it tracks all ThingHandlerFactory
s from the binding.
The ThingManager
determines if the Thing
is initializable or not.
A Thing
is considered as initializable if all required configuration parameters (cf. property parameter.required in Configuration Description) are available.
If so, the method ThingHandler.initialize()
is called.
To achieve that, the status must be reported to the framework via the callback or BaseThingHandler.updateStatus(...)
for convenience.
Furthermore, the framework expects initialize()
to be non-blocking and to return quickly.
Also, please note that the framework expects the initialize()
method to handle anticipated error situations gracefully and set the thing to OFFLINE with the corresponding status detail (e.g. COMMUNICATION_ERROR or CONFIGURATION_ERROR including a meaningful description) instead of throwing exceptions.
If the Thing
is not initializable the configuration can be updated via ThingHandler.handleConfigurationUpdate(Map)
The binding has to notify the ThingManager
about the updated configuration by a callback.
The ThingManager
tries to initialize the ThingHandler
resp. Thing
again.
After the handler is initialized, the handler must be ready to handle methods calls like handleCommand
and handleUpdate
, as well as thingUpdated
# Shutdown
Handler is unregistered:
ThingHandler
instance is no longer tracked by the framework. TheThingHandlerFactory
can unregister handler services (e.g.FirmwareUpdateHandler
) if registered, or release resources.Handler is disposed:
ThingHandler.disposed()
method is called. The framework expectsdispose()
to be non-blocking and to return quickly. For longer running disposals, the implementation has to take care of scheduling a separate job.
# Bridge Status Changes
A ThingHandler
is notified about Bridge status changes to ONLINE and OFFLINE after a BridgeHandler
has been initialized.
Therefore, the method ThingHandler.bridgeStatusChanged(ThingStatusInfo)
must be implemented
To retrieve the configuration of a Thing one can call getThing().getConfiguration()
inside the ThingHandler
The configuration class has the equivalent methods as the Map
interface, thus the method get(String key)
can be used to retrieve a value for a given key.
Moreover the configuration class has a utility method as(Class<T> configurationClass)
that transforms the configuration into a Java object of the given type.
The following types are supported for configuration values: Boolean
, boolean
, String
, BigDecimal
, int
, long
, float
and double
# Properties
Things can have properties. If you would like to add meta data to your thing, e.g. the vendor of the thing, then you can define your own thing properties by simply adding them to the thing type definition. The properties section here explains how to specify such properties.
To retrieve the properties one can call the operation getProperties
of the corresponding org.openhab.core.thing.type.ThingType
instance.
Therefore the org.openhab.core.thing.Thing
interface also provides the getProperties
operation to retrieve the defined properties.
In contrast to the getProperties
operation of the thing type instance the result of the thing´s getProperties
operation will also contain the properties updated during runtime (cp. the thing handler documentation).
# Handling Commands
For handling commands the ThingHandler
interface defines the handleCommand
method.
Inside the handleCommand
method binding specific logic can be executed.
The following code block shows a typical implementation of the handleCommand
method:
@Override
try {
switch (channelUID.getId()) {
case CHANNEL_TEMPERATURE:
break;
a user-interface requested a refreshed value, if will send a RefreshType
command.
@Override
updateWeatherData();
break;
case CHANNEL_HUMIDITY:
In this example, when a RefreshType
command is sent to the ThingHandler
it updates the weather data by executing an HTTP call in the updateWeatherData
method and sends a state update via the updateState
method.
# Updating the Channel State
For this the binding developer can call a method from the BaseThingHandler
class like this:
# Polling for a State
The BaseThingHandlerFactory
has an accessible ScheduledExecutorService
, which can be used to schedule a job.
The following code block shows how to start a polling job in the initialize method of a ThingHandler
, which runs with an interval of 30 seconds:
@Override
public void initialize() {
private void pollingCode() {
@Override
public void dispose() {
final job = pollingJob;
if (job != null) {
job.cancel(true);
pollingJob = null;
# Trigger a channel
triggerChannel("channelId")
# Updating the Thing Status
The second argument of the method takes a ThingStatusDetail
enumeration value, which further specifies the current status situation.
After the thing is created, the framework calls the initialize
method of the handler.
At this time the state of the thing is INITIALIZING as long as the binding sets it to something else.
Because of this the default implementation of the initialize()
method in the BaseThingHandler
just changes the status to ONLINE.
Additionally, REMOVED must be set after handleRemoval()
has completed the removal process.
# Channel Links
The ThingHandler
has two callback methods channelLinked(ChannelUID channelUID)
and channelUnlinked(ChannelUID channelUID)
, which are called for every link that is added or removed to/from a channel.
The channelLinked
method is only called, if the thing handler has been initialized (status ONLINE/OFFLINE/UNKNOWN).
To actively check if a channel is linked, you can use the isChannelLinked(ChannelUID channelUID)
method of the ThingHandlerCallback
If the BaseThingHandler
class is used, it provides some helper methods for modifying the thing.
# Updating the Configuration
If the configuration should be updated, then the binding developer can retrieve a copy of the current configuration by calling editConfiguration()
The updated configuration can be stored as a whole by calling updateConfiguration(Configuration)
Suppose that an external system causes an update of the configuration, which is read in as a DeviceConfig
instance.
# Updating Thing Properties
updateProperties(properties);
If only one property must be changed, there is also a convenient method updateProperty(String name, String value)
# Handling Thing Updates
If the structure of a thing has been changed during runtime (after the thing was created), the binding is informed about this change in the ThingHandler within the thingUpdated
method.
has a default implementation for this method:
@Override
dispose();
this.thing = thing;
initialize();
the framework does not call the thingUpdated
method to avoid infinite loops.
# Bridges
We have a FAQ, discussing Thing, Bridge and Channel modelling.
When implementing a binding with Bridges, the logic to communicate with the external system is often shared between the different ThingHandler
implementations.
The following excerpt shows how the HueLightHandler
delegates the command for changing the light state to the HueBridgeHandler
@Override
break;
case CHANNEL_ID_COLOR:
Inside the BridgeHandler
the list of Things can be retrieved via the getThings()
call.
A BridgeHandler
handles the communication between the openHAB framework and a bridge (a device that acts as a gateway to enable the communication with other devices) represented by a Bridge
instance.
Therefore, the BridgeHandler
interface extends the ThingHandler
interface.
# The BaseBridgeHandler
openHAB provides an abstract implementation of the BridgeHandler
interface named BaseBridgeHandler
# Life cycle
A BridgeHandler
has the same life cycle than a ThingHandler
(created by a ThingHandlerFactory
, well defined life cycle by handler methods initialize()
and dispose()
, see chapter Life Cycle).
- A
BridgeHandler
of a bridge is initialized beforeThingHandler
s of its child things are initialized. - A
BridgeHandler
is disposed after allThingHandler
s of its child things are disposed.
A BridgeHandler
is notified about the initialization and disposal of child things.
interface provides the two methods childHandlerInitialized(ThingHandler, Thing)
and childHandlerDisposed(ThingHandler, Thing)
# Config Status Provider
For this purpose the handler of the entity implements the interface org.openhab.core.config.core.status.ConfigStatusProvider
A ThingHandler as handler for the thing entity can provide the configuration status of the thing by implementing the org.openhab.core.config.core.status.ConfigStatusProvider
interface.
For things that are created by sub-classes of the BaseThingHandlerFactory
the provider is already automatically registered as an OSGi service if the concrete thing handler implements the configuration status provider interface.
org.openhab.core.thing.binding.ConfigStatusThingHandler
extends theBaseThingHandler
and is to be used if the configuration status is to be provided for thing entitiesorg.openhab.core.thing.binding.ConfigStatusBridgeHandler
extends theBaseBridgeHandler
and is to be used if the configuration status is to be provided for bridge entities
Sub-classes of these handlers must only override the operation getConfigStatus
to provide the configuration status in form of a collection of org.openhab.core.config.core.status.ConfigStatusMessage
s.
For this purpose there must be an i18n properties file inside the bundle of the configuration status provider that has a message declared for the message key of the ConfigStatusMessage
The actual message key is built by the operation withMessageKeySuffix(String)
of the message´s builder in the manner that the given message key suffix is appended to config-status."config-status-message-type.".
If a thing should be removed, the framework informs the binding about the removal request by calling handleRemoval
at the thing/bridge handler.
The thing will not be removed from the runtime until the binding confirms the deletion by setting the thing status to REMOVED
If no special removal handling is required by the binding, you do not have to care about removal because the default implementation of this method in the BaseThingHandler
class just calls updateStatus(ThingStatus.REMOVED)
After the device was successfully unpaired, the binding must inform the framework that the thing was removed by setting the thing status to REMOVED
After the removal was requested (i.e. the thing is in REMOVING
state), it cannot be changed back anymore to ONLINE
/OFFLINE
/UNKNOWN
by the binding.
The binding may only initiate the status transition to REMOVED
# Actions bound to a Thing
Examples are:
- Reboot / Restart device
If you implement the ThingActions
interface, you can tell the framework about your Thing related actions.
Please note that for actions not related to Things you will instead implement an ActionHandler
as described in the developing Module Types chapter.
You start things off by implementing ThingActions
and annotate your class with @ThingActionsScope
@NonNullByDefault
@Override
@Override
The second step is to return this class in your Thing handlers getServices()
method:
@Override
return Collections.singleton(MQTTActions.class);
As you can see in the above MqttActions
implementation, the framework will call you back with the ThingHandler
You are now free to specify as many actions as you want in MqttActions
In the following example we provide a "publishMQTT" action.
An action must be annotated with @RuleAction
, a label and a description must be provided.
public void publishMQTT(
Each parameter of an action member method must be annotated with @ActionInput
If you return values, you do so by returning a Map<String,Object>
and annotate the method itself with as many @ActionOutput
s as you will return map entries.
TODO
Bindings can implement the DiscoveryService
interface and register it as an OSGi service to inform the framework about devices and services, that can be added as things to the system (see also Inbox & Discovery Concept).
There must still be the ability to configure the binding via text files (.things
and .items
), also if you implement an automatic discovery of Things.
The following table gives an overview about the main parts of a DiscoveryResult
Field | Description |
thingUID | The thingUID is the unique identifier of the specific discovered thing (e.g. a device's serial number). It must not be constructed out of properties, that can change (e.g. IP addresses). A typical thingUID could look like this: hue:bridge:001788141f1a |
thingTypeUID | Contrary to the thingUID is the thingTypeUID that specifies the type the discovered thing belongs to. It could be constructed from e.g. a product number. A typical thingTypeUID could be the following: hue:bridge . |
bridgeUID | If the discovered thing belongs to a bridge, the bridgeUID contains the UID of that bridge. |
properties | The properties of a DiscoveryResult contain the configuration for the newly created thing. |
label | The human readable representation of the discovery result. Do not put IP/MAC addresses or similar into the label but use the special representationProperty instead. |
representationProperty | The name of one of the properties or configuration parameters, which best discriminates the result from other results of the same type. See chapter Representation Property below. |
To simplify the implementation of custom discovery services, an abstract base class AbstractDiscoveryService
implements the DiscoveryService
and just needs to be extended.
Subclasses of AbstractDiscoveryService
do not need to handle the DiscoveryListeners
themselves, they can use the methods thingDiscovered
and thingRemoved
to notify the registered listeners.
Most of the descriptions in this chapter refer to the AbstractDiscoveryService
For UPnP and mDNS there already are generic discovery services available.
Bindings only need to implement a UpnpDiscoveryParticipant
resp. mDNSDiscoveryParticipant
For details refer to the chapters UPnP Discovery and mDNS Discovery.
The following example is taken from the HueLightDiscoveryService
, it calls thingDiscovered
for each found light.
It uses the DiscoveryResultBuilder
to create the discovery result.
if (thingUID != null) {
This list will be given to the constructor of AbstractDiscoveryService
and can be requested by using DiscoveryService#getSupportedThingTypes
method.
# Representation Property
When comparing representation properties, the framework checks for matches between the representation property of the newly discovered Thing, and both the properties
and the configuration parameters
of existing Things.
If defining a representation property for a bridge, the representation property does not need to be globally unique, but only unique within the context of the bridge, so long as the discovery service calls .withBridge(bridgeUID)
when building the DiscoveryResult. e.g. if bridge A. has child Things with representation properties of 1, 2, and 3, and bridge B. also has child Things with representation properties of 1, 2, and 3, they will not conflict.
.build();
.build();
In the case that a property
will be used to match the representation property its value must be set in the Thing handler's initialize()
method:
Alternatively in the case that a configuration parameter
will be used to match the auto discovery representation property, the parameter must be declared in either, a) the thing-types.xml
file, or b) the config-description
XML file.
And it must also be declared in the Thing handler's Configuration
class:
public String uniqueId;
The Discovery
class of a binding which implements AbstractDiscoveryService
should be annotated with
where <binding-id>
is the id of the binding, i.e. astro
for the Astro binding.
# Background Discovery
If the implemented discovery service enables background discovery, the AbstractDiscoveryService
class automatically starts it.
If background discovery is enabled, the framework calls AbstractDiscoveryService#startBackgroundDiscovery
when the binding is activated and AbstractDiscoveryService#stopBackgroundDiscovery
when the component is deactivated.
The thingDiscovered
method can be used to notify about a newly discovered thing.
@Override
@Override
wemoDiscoveryJob = null;
# Active Scan
If the user triggers an active scan for a binding or specific set of thing types, the method startScan
of each discovery service which supports these thing type is called.
The following example implementation for startScan
, that triggers a scan for known and also for new lights of the hue bridge.
@Override
public void startScan() {
if (lights != null) {
for (FullLight l : lights) {
onLightAddedInternal(l);
// search for unpaired lights
The getThingUID
method of the discovery service should create a consistent UID every time the same thing gets discovered.
# Ending an Active Scan
As described above an active scan is initiated via startScan
There is no explicit end to an active scan and discovery results can be provided even after startScan
completes (e.g. from a separate thread).
If you would like assistance with enforcing a scan end pass a timeout to the AbstractDiscoveryService
constructor.
stopScan
will then be called on your discovery service upon timeout expiration allowing you to stop your scan however needed.
If a timeout is specified the scan will be considered active until the timeout expires even if startScan
completed beforehand.
If you override stopScan
don't forget to call super.stopScan
as AbstractDiscoveryService
performs some cleanup in its version.
If the timeout is set to 0 stopScan
will not be called.
# Remove older results
If this behavior is not appropriate for the implemented discovery service, one can override the method stopScan
to call removeOlderResults
as shown in the following example from the Hue binding:
@Override
super.stopScan();
The framework will take care of internationalizing labels of discovery results if you extend the AbstractDiscoveryService
Hint!
To make it work you have to inject references to the LocaleProvider
and the TranslationProvider
services into your implementation.
The AbstractDiscoveryService
already provides protected
properties, which are not yet linked to a service.
The developer has to take care about that.
# UPnP Discovery
UPnP discovery is implemented in the framework as UpnpDiscoveryService
To facilitate the development, binding developers only need to implement a UpnpDiscoveryParticipant
getSupportedThingTypeUIDs
- Returns the list of thing type UIDs that this participant supports. The discovery service uses this method of all registered discovery participants to return the list of currently supported thing type UIDs.getThingUID
- Creates a thing UID out of the UPnP result or returnsnull
if this is not possible. This method is called from the discovery service during result creation to provide a unique thing UID for the result.createResult
- Creates theDiscoveryResult
out of the UPnP result. This method is called from the discovery service to create the actual discovery result. It uses thegetThingUID
method to create the thing UID of the result.getRemovalGracePeriodSeconds
(OPTIONAL) - Returns an additional grace period delay in seconds before the device will be removed from the Inbox. This method is called when the discovery service is about to remove a Thing from the Inbox. Some bindings handle devices that can sometimes be a bit late in sending their 'ssdp:alive' notifications even though they have not really gone offline. This means that the device is repeatedly removed from, and (re)added to, the Inbox. To prevent this, a binding may OPTIONALLY implement this method to specify an additional delay period (grace period) to wait before the device is removed from the Inbox.
The following example shows the implementation of the UPnP discovery participant for the Hue binding, the HueBridgeDiscoveryParticipant
@Override
return Collections.singleton(THING_TYPE_BRIDGE);
@Override
if (uid != null) {
return result;
return null;
@Override
if (details != null) {
if (modelDetails != null) {
if (modelName != null) {
return null;
The following is an example of how to implement the OPTIONAL getRemovalGracePeriodSeconds
method.
@Component(configurationPid = "discovery.hue")
private long removalGracePeriodSeconds = 15;
@Activate
public void activate(@Nullable Map<String, Object> configProperties) {
updateRemovalGracePeriod(configProperties);
@Modified
public void modified(@Nullable Map<String, Object> configProperties) {
private void updateRemovalGracePeriod(Map<String, Object> configProperties) {
if (configProperties != null) {
Object value = configProperties.get(HueBindingConstants.REMOVAL_GRACE_PERIOD);
if (value != null) {
try {
removalGracePeriodSeconds = Integer.parseInt(value.toString());
} catch (NumberFormatException e) {
logger.warn("Configuration property '{}' has invalid value: {}",
HueBindingConstants.REMOVAL_GRACE_PERIOD, value);
@Override
public long getRemovalGracePeriodSeconds(ServiceInfo serviceInfo) {
# mDNS Discovery
mDNS discovery is implemented in the framework as MDNSDiscoveryService
To facilitate the development, binding developers only need to implement a MDNSDiscoveryParticipant
getServiceType
- Defines the mDNS service type (opens new window).getSupportedThingTypeUIDs
- Creates a thing UID out of the mDNS service info or returnsnull
out of the mDNS result. This method is called from the discovery service to create the actual discovery result. It uses thegetThingUID
(OPTIONAL) - Returns an additional grace period delay in seconds before the device will be removed from the Inbox. This method is called when the discovery service is about to remove a Thing from the Inbox. Some bindings handle devices that can sometimes be a bit late in sending their mDNS notifications even though they have not really gone offline. This means that the device is repeatedly removed from, and (re)added to, the Inbox. To prevent this, a binding may OPTIONALLY implement this method to specify an additional delay period (grace period) to wait before the device is removed from the Inbox. See the example code for thegetRemovalGracePeriodSeconds()
method under the "UPnP Discovery" chapter above.
Binding additional services to a handler can be achieved by implementing the service as a ThingHandlerService
Instead of using the Component annotation your discovery service implements the ThingHandlerService
It should extend the AbstractDiscoveryService
(which implements DiscoveryService
) just like a normal service:
public class <your binding bridge DiscoveryService> extends AbstractDiscoveryService
implements ThingHandlerService {
The interface ThingHandlerService
has 2 methods to pass the handler of the bridge.
A typical implementation is:
@Override
if (handler instanceof <your binding handler>) {
bridgeHandler = (<your binding handler>) handler;
@Override
return bridgeHandler;
The setThingHandler
is called by the openHAB framework and give you access to the binding bridge handler.
The handler can be used to get the bridge UID or to get access to the configured device connected to the bridge handler.
This is done by implementing the getServices
method in your bridge handler:
@Override
return Collections.singleton(<your binding bridge DiscoveryService>.class);
Various add-on related questions are answered in our Add-on development FAQ.
