# Sitemaps
- Concepts
- Element Types
- Element Type 'Frame'
- Element Type 'Default'
- Element Type 'Text'
- Element Type 'Group'
- Element Type 'Switch'
- Element Type 'Buttongrid'
- Element Type 'Selection'
- Element Type 'Setpoint'
- Element Type 'Slider'
- Element Type 'Colorpicker'
- Element Type 'Input'
- Element Type 'Webview'
- Element Type 'Mapview'
- Element Type 'Image'
- Element Type 'Video'
- Element Type 'Chart'
- Mappings
- Dynamic Sitemaps
- Full Example
- Further notes and comparison details
Sitemaps are text files with the .sitemap
extension, and are stored in the $OPENHAB_CONF/sitemaps
directory.
Sitemaps follow the syntax described in this article.
The openHAB runtime distribution comes with a demo configuration package containing a sitemap file named demo.sitemap
(opens new window).
You may find it useful to use this file as a starting point in creating a sitemap that fits your personal home setup.
Frame label="Date" {
Text item=Date
Frame label="Demo" {
Group item=Heating
Text item=LR_Multimedia_Summary label="Multimedia [%s]" staticIcon="video" {
Slider item=LR_TV_Volume
This textual UI configuration will produce a user interface similar to this:
# Concepts
# Elements
Sitemaps are composed by arranging various user interface elements.
A set of different element types supports a user-friendly and clear presentation.
The example above contains Frame
, Text
and Switch
elements among others.
Elements present information, allow interaction and are highly configurable based on the system state.
One line of Sitemap element definition produces one corresponding UI element.
As shown in the example, each element generates a descriptive text next to an icon on the left side and a status and/or interaction elements on the right.
# Nested Elements
# Frames
By encapsulating elements with curly brackets, multiple elements can be nested inside or behind others.
The Frame
element type is often used in combination with element blocks.
Frames are used to visually distinguish multiple elements of the same topic on one interface page.
Text item=Date
Group item=Heating
When you are using Frame
elements at one hierarchy level of your sitemap, you can not use any other element type besides Frame
Different elements can be used on the previous or next hierarchy level.
# Blocks
When using code blocks behind other element types such as Text
or Group
, these UI elements will, in addition to their normal function, be links to a new view, presenting the nested elements.
# Special Element 'sitemap'
The sitemap
element is mandatory in a Sitemap definition.
This element shall be the first line in the sitemap file, and the following code block comprises the entire Sitemap definition.
[all sitemap elements]
sitemapname
shall always be equal to the Sitemaps file name, e.g. thesitemapname
in a sitemap file nameddemo.sitemap
must be "demo"label
is free text and will be shown as the title of the main screen.
(Note that the element sitemap
is written with a lower case "s".)
# Parameters
A certain set of parameters can be configured to customize the presentation of an element.
In the shown example item
, label
and valuecolor
are parameters.
Almost all parameters are optional, some are however needed to result in a meaningful user interface.
To avoid very long or unstructured lines of element definition, parameters can be broken down to multiple code lines.
# Dependencies
A typical sitemap contains dozens of individual elements. A system state and possible interactions are however often closely dependent. openHAB supports these dependencies by providing parameters for dynamic behavior. Be sure to check out the Dynamic Sitemaps chapter.
# Element Types
Element | Description |
Buttongrid | Renders a grid of stateless buttons used to send commands to a given Item. |
Chart | Adds a time-series chart object for persisted data. |
Colorpicker | Allows the user to choose a color from a color wheel. |
Default | Renders an Item in the default UI representation specified by the type of the given Item. |
Frame | Establishes an area containing various other Sitemap elements. |
Group | Concentrates all elements of a given group in a nested block. |
Image | Renders an image given by an URL. |
Input | Renders an input field for text or numbers. |
Mapview | Displays an OSM map based on a given Location Item. |
Selection | Provides a dropdown or modal popup presenting values to choose from for an Item. |
Setpoint | Renders a value between an increase and a decrease buttons. |
Slider | Presents a value in a progress-bar-like slider. |
Switch | Renders an Item as an ON/OFF or multi-button switch. |
Text | Renders an Item as text. |
Video | Displays a video stream, given a direct URL. |
Webview | Displays the content of a webpage. |
Choosing the right element type:
Data presented by Sitemap elements will almost always originate from a referenced Item.
Each Item is of a certain Item type, for example Switch
, Number
or String
In the following definitions, parameters in
[square brackets]
are optional.Parameters must be supplied in the order shown.
Common parameters, also known from items definition:
item
defines the name of the Item you want to present (e.g.Temperature
), more details.label
sets the textual description displayed next to the preprocessed Item data (e.g. "Now [%s °C]
"), more details.icon
chooses the icon to show next to the element, more details.
When an Item is defined, you have the opportunity to assign a label and/or an icon at that point. If no label or icon are specified in the Sitemap, then the label and/or icon you assigned to the Item will be displayed. Setting a value for
label
oricon
orstaticIcon
of a Sitemap element will override the values defined for the linked Item. There is an exception for chart, image, video, mapview and webview Sitemap elements: the item label is ignored and only the value oflabel
is considered for the label.The parameters
icon
andstaticIcon
are exclusive; both allow choosing the icon to show next to the element butstaticIcon
also indicates not to try to create a dynamic icon (using the current state of a linked item). The value of these two parameters can optionally be enclosed in double quotes.
It has to be considered that if the label defined in a Channel or an Item contains text and state, these representations have to be overwritten separately in the Sitemap. In the following example an Item which has a label and state defined is overwritten.
Frame label="Temperature" {
UoM = Units of Measurement
- Additional parameters such as
mappings
andvaluecolor
are described below.
# Element Type 'Frame'
Frame [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] {
[additional sitemap elements]
//# and so on...
# Element Type 'Default'
Default item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>]
Presents an Item using the default UI representation specified by the type of the given Item.
E.g., a Dimmer
Item will be represented as a Slider element while a Player
Item will be rendered with player button controls (Previous/Pause/Play/Next).
# Element Type 'Text'
Text [item=<itemname>] [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>]
Text item=Temperature label="Livingroom [%.1f °C]" staticIcon=temperature
# Element Type 'Group'
Group item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>]
item
refers to the name of the Item group to be presented.
# Element Type 'Switch'
Switch item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] [mappings="<mapping definition>"]
Switches are one of the more common elements of a typical Sitemap.
A Switch will present a discrete state Item and allow changing of its value.
Note that Switch elements can be rendered differently on the user interface, based on the Item type and the mappings
parameter.
mappings
comes as an array of value-to-string translations, documented further down. Without the mappings parameter, user interfaces will present an On/Off Switch, if mappings are given, several buttons with label or icon will be rendered.
Switch item=LR_CeilingLight label="Ceiling Light" icon=light
# Element Type 'Buttongrid'
Buttongrid item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] [buttons="<Button definition>"]
A Buttongrid represents a grid of buttons and enables commands to be sent to an Item. When a button is pressed, the associated command is sent to the linked Item. Buttons never appear as selected, they do not display the current state of the linked Item.
This is a typical element for simulating a remote control, for example.
label
if set, a header row will be displayed containing this label and the icon.buttons
defines the position of each button within the grid and the command associated with each button; provided as an array.
Buttons syntax:
buttons=[row_1:column_1:command_1="description_1", row_2:column_2:command_2="description_2"=<iconname>, ...]
The buttons can be defined in any order, their position in the grid is defined by a row index and a column index. The top left position is row index 1 and column index 1. The grid must not exceed 12 columns so the maximum allowed column index is 12 columns. It is not mandatory to define a button in all grid cells. The user interfaces will automatically determine the grid size so that all buttons are presented.
The content of each button can be text but also an icon; the icon will be used by default if provided.
Buttongrid label="Remote Control" staticIcon=screen item=RemoteControl buttons=[1:1:POWER="Power"=switch-off , 1:2:MENU="Menu" , 1:3:EXIT="Exit" , 2:2:UP="Up"=f7:arrowtriangle_up , 4:2:DOWN="Down"=f7:arrowtriangle_down , 3:1:LEFT="Left"=f7:arrowtriangle_left , 3:3:RIGHT="Right"=f7:arrowtriangle_right , 3:2:OK="Ok" , 2:4:VOL_PLUS="Volume +" , 4:4:VOL_MINUS="Volume -" , 3:4:MUTE="Mute"=soundvolume_mute]
# Element Type 'Selection'
Selection item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] [mappings="<mapping definition>"]
mappings
# Element Type 'Setpoint'
Setpoint item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] minValue=<min value> maxValue=<max value> step=<step value>
minValue
(defaults to 0) andmaxValue
(defaults to 100) limit the possible range of the value (both included in the range).step
(defaults to 1) defines how much the value will change when the button is pressed one time.
# Element Type 'Slider'
Slider item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] [sendFrequency="frequency"] [switchSupport] [minValue=<min value>] [maxValue=<max value>] [step=<step value>]
sendFrequency
is used to distinguish between long and short button presses in the classic (web) frontend. This parameter defines the interval in milliseconds for sending increase/decrease requests.switchSupport
is a parameter without an assignment.- Android app: If specified, a short press on the item row (except the slider itself) switches the item "on" or "off".
- This parameter has no effect in other UIs.
minValue
(defaults to 1) defines the distance between two possible/selectable datapoints on the slider.
# Element Type 'Colorpicker'
Colorpicker item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] [sendFrequency=<sendFrequency>]
This element is a combined control for something like a rgb or rgbw light where you can adjust brightness as well es the color hue. The down-button decreases brightness to zero and switches the light off. The up-button sets brightness to full but keeps the previous color (hue). The middle button opens an overlay to finetune your color. A color wheel let you pick the hue and a slider allows to set the brightness.
sendFrequency
Colorpicker item=LR_LEDLight_Color label="LED Light Color" staticIcon=colorwheel
# Element Type 'Input'
Input item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] [inputHint="<inputHint>"]
This element allows entering of text, numbers and dates/times and updating the underlying items.
This can for example be useful to update manually collected meter readings and storing the information in an item.
Text, number or number with unit values and dates/times can be updated in the respective item types.
Formatting in the label parameter will format the current value, but the value update will be as entered in the field.
E.g. this makes it possible to use formatting like [%.0f %unit%]
to show the current value without fractions, but still update to whatever is entered.
inputHint
will give a hint to the user interface to use a specific widget adapted to a specific use. Valid values for the parameter aretext
,number
,date
,time
anddatetime
. Support of these widget types vary by user interface and/or browser.
Note that this element type may not be supported on all user interfaces that support sitemaps.
Input item=Meter_Reading label="Meter [%.0f %unit%]" staticIcon=energy inputHint="number"
# Element Type 'Webview'
Webview item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] url="<url>" [height=<heightvalue>]
label
if set, a header row will be displayed containing this label and the icon.height
is the number of element rows to fill.
# Element Type 'Mapview'
Mapview [item=<itemname>] [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] [height=<heightvalue>]
label
# Element Type 'Image'
Image [item=<itemname>] [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] url="<url of image>" [refresh=xxxx]
This element type is able to present an image.
The image must be available on a reachable website or webserver without password or access token.
Alternatively, the image file (e.g. YourImageFile.png) may be stored locally in the $OPENHAB_CONF/html folder, and will be accessible through the static route, https://<my.openHAB.device>:8080/static/YourImageFile.png
label
if set, a header row will be displayed containing this label and the icon.item
can refer to either an Image Item whose state is the raw data of the image, or a String Item whose state is an URL that points to an image. Some clients may not (yet) consideritem
.url
is the default URL from which to retrieve the image, if there is no associated Item or if the associated item's state is not a URL.refresh
is the refresh period of the image in milliseconds ("60000" for minutely updates).
# Element Type 'Video'
Video [item=<itemname>] [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] url="<url of video to embed>" [encoding="<video encoding>"]
label
can refer to a String Item whose state is a URL to a video. Some clients may not (yet) consideritem
.url
is the default URL from which to retrieve the video if there is no associated Item or if the associated item's state is not a URL.encoding
should be set to "mjpeg" for an MJPEG video, or "HLS" for an HTTP Live Streaming playlist (file with .m3u8 extension). If you omit theencoding
parameter, openHAB will attempt to automatically select the correct format.
# Element Type 'Chart'
Chart item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] [refresh=xxxx]
period=xxxx [service="<service>"] [legend=true/false] [forceasitem=true/false] [yAxisDecimalPattern=xxxx]
label
if set, a header row will be displayed containing this label and the icon.refresh
defines the refresh period of the Image (in milliseconds).service
sets the persistence service to use. If no service is specified, openHAB will use the first queryable persistence service it finds. Therefore, for an installation with only a single persistence service, this is not required.period
is the scale of the time axis. Valid values areh, 2h, 3h, ..., D, 2D, 3D, ..., W, 2W, 3W, ..., M, 2M, 3M, ..., Y, 2Y, ...
and any valid duration following the ISO8601 duration notation such asP1Y6M
for the last year and a half orPT1H30M
for the last hour and a half.legend
is used to show or to hide the chart legend. Valid values aretrue
(always show the legend) andfalse
(never show the legend). If this parameter is not set, the legend is hidden if there is only one chart series.forceasitem
is used to show the value of aGroup
instead of showing a graph for each member (which is the default).yAxisDecimalPattern
is used to format the values on the y axis. It accepts DecimalFormat (opens new window). For example with#.##
a number has to decimals.
Visit Charts (opens new window) in the Wiki for examples.
- When using rrd4j persistence, the strategy
everyMinute
(60 seconds) has to be used. Otherwise no data will be persisted (stored) and the chart will not be drawn properly (see rrd4j Persistence). - The visibility of multiple Chart objects may be toggled to simulate changing the Chart period; non-visible Chart widgets are NOT generated behind the scenes until they become visible.
- When charting a group of item, make sure that every label is unique.
# Mappings
Mapping syntax:
mappings=[value_1="description_1", value_2="description_2"=<iconname>, ...]
mappings=[ON="Mic On"=material:mic, OFF="Mic Off"=material:mic_off]
In the fifth example above, user interfaces will display buttons using the provided icon rather than the provided description. Icons are usable in Switch element but ignored in Selection element.
# Dynamic Sitemaps
- Show a battery warning if the voltage level of a device is below 30%
- Hide further control elements for the TV if it is turned off
- Highlight a value with a warning color if it is outside accepted limits
- Present a special icon, depending on the state of an item (a dynamic icon)
# Visibility
The visibility
parameter is used to dynamically show or hide an Item.
If the parameter is not provided, the default is to display the Item.
Visibility syntax:
visibility=[item_name operator value, item_name operator value AND item_name operator value, ... ]
You can set as many conditions as you want.
A condition can be a single comparison or a combination of several comparisons all separated by the AND operator. A condition including the AND operator will be considered as true if all individual comparisons are considered as true. Of course, it is possible to reference a different item in each comparison.
Note that item_name
and operator
are both optional.
If item_name
is not provided, the Item name will default to the current Item.
If an operator is not specified, the operator will default to ==
- equal to
, unequal to!=
- less than or equal to
, greater than or equal to>=
- less than
, greater than>
Expressions are evaluated from left to right.
The Item will be visible if any one of the conditions is evaluated as true
, otherwise it will be hidden.
Switch item=CinemaLight label="Cinema light" visibility=[TV_Power==ON]
Switch item=LawnSprinkler visibility=[Day_Time=="Morning" AND Temperature>19]
In the third example above, a control for a lawn sprinkler will be visible if it is Morning, OR if it is Afternoon, OR if the temperature is above 19 °C. In the fourth example above, multiple conditions are combined, a control for a lawn sprinkler will be visible if it is Morning AND if the temperature is above 19 °C.
# Label, Value and Icon Colors
Colors can be used to emphasize an items label or its value based on conditions. Colors may be assigned to either the label or the value associated with an Item. The icon may be tinted depending on the state as well.
Label, Value and Icon Color Syntax:
labelcolor=[item_name operator value = "color", item_name operator value AND item_name operator value = "color", ... ]
valuecolor=[item_name operator value = "color", item_name operator value AND item_name operator value = "color", ... ]
iconcolor=[item_name operator value = "color", item_name operator value AND item_name operator value = "color",... ]
You can set as many conditions as you want, along with a color for each condition.
Note that item_name
and operator
are both optional.
If item_name
If only a color is specified, that condition is considered as true and that color will be used. Providing only a color can be used as a last condition to set a default color that will be used in case any of the other previous conditions is true.
The comparison operators for labelcolor
, valuecolor
and iconcolor
are the same as for the visibility parameter.
Text item=Temperature labelcolor=[>0="blue"] valuecolor=[22="green"] iconcolor=[22="green"]
Text item=Temperature labelcolor=[>0="blue"] valuecolor=[==22="green"] iconcolor=[==22="green"]
Text item=Temperature labelcolor=[Temperature>0="blue"] valuecolor=[Temperature==22="green"] iconcolor=[Temperature==22="green"]
The line below illustrates setting a default color (gray) and how to combine multiple comparisons with an AND operator:
Text item=NumberItem labelcolor=[>0 AND <50="yellow", >=50="green", "gray"] valuecolor=[>0 AND <50="yellow", >=50="green", "gray"] iconcolor=[>0 AND <50="yellow", >=50="green", "gray"]
Note that expressions are evaluated from left to right; the first matching expression determines the color.
If the order of the expressions was reversed, the color assignment would not work.
Note also, the effect of omitting Temperature
and the comparison operator in the expression 0="white"
(as compared to ==0="white"
Color Name | Preview | RGB Color Code |
maroon | ⬤ | #800000 |
red | ⬤ | #ff0000 |
orange | ⬤ | #ffa500 |
olive | ⬤ | #808000 |
yellow | ⬤ | #ffff00 |
purple | ⬤ | #800080 |
fuchsia | ⬤ | #ff00ff |
pink | ⬤ | #ffc0cb |
white | ⬤ | #ffffff |
lime | ⬤ | #00ff00 |
green | ⬤ | #008000 |
navy | ⬤ | #000080 |
blue | ⬤ | #0000ff |
teal | ⬤ | #008080 |
aqua | ⬤ | #00ffff |
black | ⬤ | #000000 |
silver | ⬤ | #c0c0c0 |
gray | ⬤ | #808080 |
gold | ⬤ | #ffd700 |
Please take note that colors other than those listed in the list above may be used.
Generally, you can expected that valid HTML colors will be accepted (e.g. green
, lightgrey
, #334455
), but note that a UI may only accept internally defined colors, or work with a special theme.
The color names above are agreed on between all openHAB UIs and are therefore your safest choice.
Colors defined by a human-readable name may be adjusted for higher contrast, e.g. on a dark theme black
may be displayed as white, because white has a higher contrast to the dark background compared to black.
There are also the following keywords that can be used as colors:
Color Name | Note |
primary | Primary theme color |
secondary | Secondary theme color |
itemValue | The state of the linked Color item |
# Icons
openHAB allows a set of icons to be assigned to the different states of an Item and therefore to be presented in a Sitemap. This first way of proceeding only considers the current state of the linked item and requires the use of icons provided by openHAB and a particular syntax of icon names. Please refer to the documentation on Item configuration for details.
There is also a more powerful way to define a dynamic icon based on the states of different items and allowing you to attach any type of icon regardless of its source (not restricted to icons provided by openHAB).
The icon
parameter can be used to provide conditional rules.
Extended icon syntax:
icon=[item_name operator value = icon, item_name operator value AND item_name operator value = icon, ... ]
You can set as many conditions as you want, along with a reference to an icon for each condition.
Note that item_name
and operator
are both optional.
If item_name
Conditions are evaluated from left to right; the first matching condition determines the icon. If only a reference to an icon is specified, that condition is considered as true and that icon will be used. Providing only a reference to an icon can be used as a last condition to set a default icon that will be used in case any of the other previous conditions is true.
The comparison operators are the same as for the visibility parameter.
Text item=TemperatureTrend icon=["UP"=f7:arrowtriangle_up, "DOWN"=f7:arrowtriangle_down, f7:arrowtriangle_right]
Text item=TemperatureTrend icon=[=="UP"=f7:arrowtriangle_up, =="DOWN"=f7:arrowtriangle_down, f7:arrowtriangle_right]
Text item=TemperatureTrend icon=[TemperatureTrend=="UP"=f7:arrowtriangle_up, TemperatureTrend=="DOWN"=f7:arrowtriangle_down, f7:arrowtriangle_right]
Text item=Date
Group item=Heating
Explanation:
The Sitemap "demo" with the shown title "My home automation" is defined.
One first Frame with a date stamp is shown.
Another Frame with a visual label "Demo" is presented, containing:
A Switch for the Item "Lights"
A Text element showing a temperature in a given format
A Group element. Upon clicking the element, a new view containing all "Heating" Items will be shown.
Another Text element showing a "Multimedia" summary, e.g. "Currently playing". The element is additionally the host for a nested block. By clicking in the element, a new view with two elements is presented:
- A Selection presenting four options in a modal dialog prompt
- A Slider to set the volume (e.g. 0-100%)
String comparisons are case sensitive, so
==ON
is not the same as==on
.DateTime comparisons are relative to the current time and specified in seconds. So the expression
Lights_On_Time > 300
will return true if the DateTime Item is set to a value that's newer than the past 5 minutes (300 seconds).Further examples for defining Sitemaps can be found in our openHAB-Samples (opens new window) section.
